- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Can the MX64W be linked/integrated with Umbrella?
Has anyone done this? I am not clear as to how after upgrading the firmware on the firewall to an Umbrella compatible version. Not finding Umbrella options anywhere.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you've followed the linked instructions, you're running beta firmware, and you're still not seeing it - have you contacted support?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Network-wide > Configure > General
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You are org admin and can see the organization part in black menu pane saying organization and you can enable API, right?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you upgraded to the beta firmware for your MX? You do need to be on the 15.x firmware for this option to be available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I did both. Do I now generate an API key (in the Meraki dashboard) for the credentials option to show up?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They had to enable the feature. They as in support.
