Hi Bruce,
Yes and I even stumped a Meraki technician tonight who also felt like my settings in Meraki were correct. So it may be the problem lays on my domain controller. I'll explain but first to confirm....
1. From Computer at site 2, yes I can ping the IP address of the DC and it resolves
2. From Computer at site 2, no I cannot ping the DC using the server name or FQDN.
3. Within Meraki MX Gateway under Security & SDWAN>Active Directory, settings are good and status = Green check. Even the LDAP Groups looked good according to Meraki support.
4. DNS settings reviewed on both MX Gateways. Each one reflects the Internet Provider's primary DNS & Google or 8.8.8.8
5. Where I think I'm stuck is about 1/3 of the way down on this link. https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
in the graphic below, I've marked where I was no longer able to follow the instructions. I'm supposed to view a certificate. The graphic after this is what I see.
This is what I see when i view my certificate. This was exported to desktop from my Certificate MMC.msc.
or from within my Certificate MMC.msc which I created based on another Meraki tutorial.
The gist of this is, that I create a certificate trust with LDAPS based on a security update from Microsoft back in 2019 or so I read. So I'm stuck at that point in the tutorial and Meraki technician concurs that it's most likely there I'll find the fix. So the real question is... what am I missing in that part of the tutorial about "Certificate Requirements for TLS"?
Thank you again.
