Can't connect Client VPN with L2TP from MacOS
Uplinker
I have many clients that can connect from windows devices but for some reason I have been unable to configure a VPN connecting that works on a MacOS Device am I overlooking something?
2 Replies 2
Mloraditch
I presume you are following the instructions here: https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration
If so, I found this, that had a couple of ideas: https://www.reddit.com/r/meraki/comments/1c7n3by/meraki_and_macos_l2tp_woes_works_in_macos_1266/
Might be worthwhile into looking into Secure Client licensing. Can eliminate a lot of issues that pop up with L2TP setups.
BlakeRichardson
1. Are you configuring the devices by hand or using an MDM profile?
2. What is the error message you are getting?
