Blocking countries on Z3
eweisman
How do you block countries in the Z3?
The normal path for an MX is Security & SD-WAN --> Configure --> Firewall --> Layer 7.
I thought the equivalent for the Z3 would be Teleworker Gateway --> Configure --> Firewall --> Layer 7. However, there is no country section under Layer 7 Firewall rules.
HaniAbuelkhair4
In order to block per country you will need an Advance security licenses.
But in Z3 this licenses is not available, so you cant do that using the Z3.
1 Reply 1
HaniAbuelkhair4
