- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
BiDi optics in MX applicance
Does anyone have experience using BiDi optics on an MX84? I see "compatible" modules on Amazon but no OEM options.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Alright, my memory is a bit off. We use the Lumentum and LambdaGain BiDi's in the MS switches and they work fine. But, it appears on a quick test that the LambdaGains DO NOT work in the MX line.
I tested between an MX84 and MS410. The following info is from the MS410 side since we can't see port info on an MX 😞
This worked in an MX84:
But the LambdGain does not:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yup. We've used BiDi's from both Lumentum and LambdaGain. They work well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for confirming @jdsilva just wanted to confirm that's on SFP ports 11/12 of an MX84 for example? I thought there may not be hardware support for BiDi, but perhaps that's on the WAN interfaces of MX250/450 perhaps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@MerakiDave I can't say for sure if we have any BiDi's in an MX84... But I have one in my lab I can test with if you're curious?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm testing this out quickly just to make sure. Standby.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
One caveat though, that applies to MX SFP's in general, is that we've found that the out of the box firmware on the MX250/450 often doesn't have proper support for certain SFPs on the WAN ports, or the SFP+ ports. My recommendation is to connect those models specificially to the cloud using a 1000Base-T SFP first, upgrade the firmware, and then you're good to go.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@jdsilva I don't have any MX250/450 or BiDi to test with, just wanted to confirm if you successfully used those 3rd party BiDi optics on both LAN and WAN (with the caveat you noted) or perhaps just the LAN side?
