You could also look at deploying the vMX100 inside a Azure VNET. I've not done it with Azure however have set it up within AWS. It's pretty simple,  just requires VPC with a IGW created and then subnets behind the xVM100, just change their route tables to point to the interface of the VMX100. I can imagine the setup is identical in Azure just with the Azure equivalents.
If you're looking at deploying quite a few Meraki sites, rather than having to manually create VPN's from each of them an vMX100 and Auto-VPN would be the way to go. otherwise if it's a small amount, I don't know if you'd be able to justify the cost (vMX100 license, running costs) etc as effectively it's just working as a VPN concentrator.
