Anyone have a slick way to block all Remote Access Tools?
Red-Five
I was hoping to find a Content category that would block remote access tools (gotomypc, logmein, etc) but didn't find one.  Anyone have a good way to setup a generic block to these types of connections?
3 REPLIES 3
Make_IT_Simple
Meraki Alumni (Retired)
I don't believe there is an easy way. I would personally search for all known ports used by remote access tools and block them.
Many of these tools have an automatic fallback to TCP/80, TCP/443 or even HTTP/S. This will likely not work.
Make_IT_Simple
Did you try blocking all remote monitoring & management?
