AnyConnect SAML w/Azure AD Enterprise application question
lesliebright
Does each individual site I want to use AnyConnect w/ SAML to Azure AD require its own Enterprise Application set up or is there a way to re-use the application for multiple MXs?
RomanMD
The Identified and Reply URL needs to point to the DNS name of the appliance, therefore I don't see it possible to use the same Enterprise application for multiple networks.
I wish I am wrong...
2 Replies 2
RomanMD
lesliebright
I think you're right. I believe the setup creates a 1:1 relationship between the MX and the Azure application. This makes me want to limit the number of possible connection points for a whole other reason now...
