AnyConnect SAML w/Azure AD Enterprise application question
Does each individual site I want to use AnyConnect w/ SAML to Azure AD require its own Enterprise Application set up or is there a way to re-use the application for multiple MXs?
The Identified and Reply URL needs to point to the DNS name of the appliance, therefore I don't see it possible to use the same Enterprise application for multiple networks.
I think you're right. I believe the setup creates a 1:1 relationship between the MX and the Azure application. This makes me want to limit the number of possible connection points for a whole other reason now...
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
