AnyConnect OnConnect scripts
hounshamp
Has anyone successfully got the AnyConnect OnConnect scripts working on a Meraki MX?
The following states that Run script on connect and disconnect is supported however I cannot find any documentation to support this on an MX.
https://documentation.meraki.com/MX/AnyConnect_on_the_MX_Appliance/AnyConnect_on_ASA_vs._MX
I am going to assume the file name is scripts_OnConnect_myscript.bat and you would upload this where the profile is uploaded.
Any real world experience appreciated.
6 Replies 6
Inderdeep
@ : Everything is here for Anyconnect on MX
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
hounshamp
Thanks but that doesn't cover anything about running scripts on login.
Looking for real world experience rather than the useless Meraki how-to guides.
I don't know the answer, but check out this section of the AnyConnect manual.  Note that this has nothing to do with Meraki.  This is an AnyConnect function.
https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/anyconnect40/administration/gui...
JH7
I was testing out OnConnect script as well (like OnConnect.bat as stated in the manual). Also, placed the script into here: %ALLUSERSPROFILE%\Cisco\Cisco AnyConnect Secure Mobility Client\Script
I've been having issue with script not executing at all. I ran my script manually and it worked.
Let me know if anyone can get it to run successfully. Appreciate it!
hounshamp
Yes got it working. So created a batch file called OnConnect_login.bat and saved it to %ALLUSERSPROFILE%\Cisco\Cisco AnyConnect Secure Mobility Client\Script
Basically anything starting with OnConnect will be executed from the directory if the run script option is enabled in the profile - Profile Editor / Preferences (Part 2) / Enable Scripting.
I uploaded the new profile to the AnyConnect section on the dashboard so it will be pulled down when the users connect next.
In my batch file I had the following calling the logon.bat from the logon server.
@echo off
rem logon script for AnyConnect users
call %logonserver%\netlogon\logon.bat
JH7
Excellent! Thank you for your help! The only thing i was missing is i didn't upload the profile to AnyConnect section on the dashboard.
