Why is there not a checkbox next to the "Remote VPN Participants" when Site-to-Site VPN is enabled?
I absolutely do NOT want to mix certain networks, or establish VPN Tunnels between them.
Example:
I have two existing sites with MX64's that use auto-mesh and work extremely well.
I need to add two more sites that do, A: automesh between themselves, but absolutely do NOT establish a VPN connection to my original two networks, and B: have a VPN tunnel to a 3rd party network.
The LAN subnet that is at the 3rd party network conflicts with the subnet for my original network, which is why I need this second set of MX64's to be completely separate.
It would seem that simple "disable" check boxes would be a perfect solution for this (or simply not automatically adding ALL networks to my Remote VPN Participants table).
As is, (correct me if i'm wrong) I would have to create a 2nd Meraki dashboard login, and operate this site as a 2nd "company" to separate these two networks from my original two networks, correct?
