Adding/Replacing an MX
Shadius
Hi Merakians,
So I recently received an MX68 and I'd like to add it to my network. My existing network already has an MX64.
My question is, would it be okay to have two MX appliances on the same network or should I just replace the MX64 with the MX68?
Thoughts, suggestions?
You can not have 2 mx in one dashboard network (only warm spare, same models)
You can have 2 mx (two separate dashboard networks)in a real network if you have a function for it.
SoCalRacer
Since you can only have 1 MX per network you will probably want to do a swap.
https://documentation.meraki.com/MX/Other_Topics/MX_Cold_Swap_Replacing_an_Existing_MX_with_a_Differ...
Shadius
Thanks, looks like a swap is what I need to do.
