I've been having some issues with creating a self-signed certificate. I tried using IIS and it created everything correct except the extended key usage setting it is missing "ClientAuth" it seems to have everything else. I also tried using OpenSSL but not having luck creating anything but V1 certificates. Everything I can find refers to the directions for sending off a CSR. I'm using this for a small business so they can use AD Auth for their VPN. I'd also like to find something that is signed for a longer time than 1 year if possible but with creating the cert via IIS I couldn't find anyway to extend that? Any help would be greatly appreciated this is not something I work with very often.
That was super easy to follow and use, the cert is up and running now. Still can't connect but I think that may be a different issue. Continuing to troubleshoot that. Thanks for the suggestion on this!
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b4f44d571e2d9","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b4f44d571e2d9_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b4f44d571e2d9_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6b4f44d571e2d9_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6b4f44cc566e42","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
