Active Directory Self Signed SSL Certificate
GregMi
I've been having some issues with creating a self-signed certificate.  I tried using IIS and it created everything correct except the extended key usage setting it is missing "ClientAuth" it seems to have everything else.  I also tried using OpenSSL but not having luck creating anything but V1 certificates.  Everything I can find refers to the directions for sending off a CSR.  I'm using this for a small business so they can use AD Auth for their VPN.  I'd also like to find something that is signed for a longer time than 1 year if possible but with creating the cert via IIS I couldn't find anyway to extend that?  Any help would be greatly appreciated this is not something I work with very often.
Accepted Solutions
CptnCrnch
Re: Active Directory Self Signed SSL Certificate
For „quick and dirty“ certificates without too much background, you could take a Look at xCA: https://hohnstaedt.de/xca/
2 REPLIES 2
CptnCrnch
GregMi
That was super easy to follow and use, the cert is up and running now.  Still can't connect but I think that may be a different issue.  Continuing to troubleshoot that.  Thanks for the suggestion on this!
