Guys, this should be a simple problem, if I could just find the right documentation!
I have a Meraki MX67, with a site-to-site VPN linking to a hub Meraki MX84 HA pair. I have client PCs successfully doing IEEE802.1x authentication on the MX67, using an ISE (v2.7) in the network at the MX84 end, so I know both ends work fine.
However, the user wants to authenticate devices with no supplicant, so needs to use MAB. The MX67 has an option to use MAB, but it fails (reject) despite the devices being configured in the ISE.
Other documentation I've found says that the ISE is looking for the "call-check" attribute when authenticating, but the MX67 doesn't provide it. As a result, the MAB fails, and indeed I can see failure notiifcations in the log and the traffic in the packet trace.
So I need to stop the ISE looking for the "call-check" attribute from the devices MAB-ing on the MX67, but I can't find anything that tells me how to do that or if its possible. Yes, I know it would be better to trunk a switch to the MX67 and do "normal" MAB on a "normal" switch port, that was my original response, but apparently a switch won't fit the budget.
If there is any document that says how to do it, can I have a link, or some idea of how to do the job. It sounds like just switching something off....?
Any hints will be gratefully recieved!
Jim
