Active-Active Auto VPN Query
Bon_clay
If I have Active-Active AutoVPN enabled and then switch oour Primary Uplink to our secondary WAN connection will the VPN tunnels stay active during the switch over or will they all drop connection as well?
2 Replies 2
Mloraditch
I would prepare for a brief blip when you do this. I do this rather frequently but it really depends on your environments on how much the end users notice it and whether the applications they use tolerate it.
Yes.
