3 x ISP WAN loadbalancing for MX250
Lingcw
Can I do load balancing for 3 x ISP on MX250?
Thank you
4 REPLIES 4
nswiatec
The MX250 currently only supports load balancing across the 2 WAN/Internet ports - i.e. 2 ISPs.
Did I help you? Please hit the green up-arrow, "kudos" button.
Thank you for your reply. In the link below, it mention that:
Load sharing is loosely defined as spreading network traffic across 2 or more equal or unequal links/paths. Load sharing can exist between a 10Mbps WAN link and a 100Mbps WAN link.
I wonder which MX model that can support 3 WAN link.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Link_Aggregation_...
Hi @Lingcw
The definition you mention is a general defintion of load sharing/balancing.
If you look further down the same page, in the "Cisco Meraki implementatino" you will see "Cisco Meraki security appliances use a proprietary algorithm to provide load balancing across two Layer 3 links (if configured). "
Hope this clarifies.
3 or more WAN load balancing is also something I would like to see . I suggest you use the "make a wish" button on your dashboard, other vendors offer the option of using more than two WANS so I don't think its a big ask.
