2 bonded HSIA on MX device
Joels2019
Hello, I have a situation where I need service for a short term.. about 3 months. I am looking to use 2 Internet access at about 50 MB each, into a MX to give me a combined BW of abut 100MB. Is this possible on the MX and do I need to have any special config on the MX?
Inderdeep
@Joels2019 Rightly said by @DarrenOC and the quick answer is yes to push the traffic on both links as load balanced
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
5 Replies 5
Inderdeep
@Joels2019 : if you talking about smart bonding then have a look
https://community.meraki.com/t5/Security-SD-WAN/Smart-link-bonding-in-MX/m-p/100920#M25288
DarrenOC
Hi @Joels2019
you can utilise both WAN links on your mX for load balancing
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
Special config: tick box to enable load balancing to utilise both links
Joels2019
Thanks for the feed back. I will try this with my customer as a fix for this short term situation. Thanks.
Inderdeep
Joels2019
Thanks Inderdeep for the input. This should effectively give me the aggregate BW of both these accesses.
