So I push pinned the reset quickly…the gr12’s rebooted and no change in firmware…they are still at 28.7.1, these (2) are hard wired to the switch.
my 2 gr10’s are at 28.6.1, these two are meshed repeaters.
the gr12’s have a 100+ millisecond latency when using the test connection icon.  This is not expected since they are hard wired using cat6 cables to 1gb ports and ports have been switched to forced gb.
the gr10’s which are meshed repeater's show a 40+ millisecond latency.  They repeat from gr12’s.
Don’t know if the gr10 40 millisecond latency will improve if the gr12 100+ millisecond  latency improves.
Not loving the idea that a restore to
Details reset is needed to get the firmware to 29.x.x
so if I don’t do a restore to defaults, the gr12’s will both be stuck at 28.x.x
no update now option in software and no check for software updates.
