First full-stack Meraki Go installed today - question on port forwarding
I did my first full stack (Firewall, Switch, WiFi) install today. No real problems, but some of the devices had to be repeatedly rebooted to get them to configure correctly.
Now that everything is in and it appears to be working well enough, customer has asked me for a VPN (they didn't ask about that before I did the install!!!)
I've got a machine inside of the network configured as a VPN server now, but I can't seem to poke any holes in the firewall.
I've got port 1701 UDP forwarded to my VPN machine, but I can't figure out where I'm getting stopped. I don't think it's a problem behind the firewall, because I've got 2 other ports forwarded to different machines, and those don't connect either.
I did an NMAP port scan on the network, and there are no open ports.
So what do I need to do to actually open the ports?
Accepted Solutions
Meraki Go Team
Meraki Go Team
Re: First full-stack Meraki Go installed today - question on port forwarding
Hi Macsolutions,
Could you please reach out to support via the app. They'll be able to check whether the port forwarding rules are being applied correctly.
Lee
2 REPLIES 2
Meraki Go Team
Meraki Go Team
Hi Macsolutions,
Lee
Did this get resolved?  I can't get any port forwarding to work either.  I've reached out to support via the app, but it's been days with no response.  I need to get this resolved.
