Handling SGT on MX from LAN to LAN
Vahid-Farahani
Dear community,
Does anybody know that Meraki MX will handle traffic with SGT tags (Cisco MetaData) without enabling Adaptive Policy on it ? the current version is 17.10.
I know that MX version 18.1 only supports preserving and propagating SGTs over autoVPN on NAT mode MXs, I need that MX handle traffic with SGT tag from LAN to LAN.
Thanks and greetings,
Vahid
5 Replies 5
Have you tried with this doc?
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Adaptive_Policy/Adapt...
Thanks for your relpy.
Yeah, I have read this doc, it has been mentioned that:
"MX version 18.1 only supports preserving and propagating SGTs over autoVPN on NAT mode MXs."
In my network the Meraki is between two Cisco devices.
KarstenI
Most important question here: Do you have LAN-switches that can handle SGTs? In the Meraki world this is only the MS390. On the Catalyst line it's 3650+ or the 9k line.
Yes LAN switch is handling the SGTs,
FYI: The traffic is coming to the Meraki with CMD, but not forwarded with Meraki to down stream switch.
If I upgrade the apliance to the 18.1+ , do you think that it will handle the traffic?
Without SGT tag, everything is working.
I think you will need to use a super new firmware to stand a chance of this working.
I would kinda expect this to require an "SD-WAN Plus" licence for this to work ... I wouldn't expect Meraki to support this without that licence.  I am only guessing at this bit.
Could you not plug the two Cisco switches directly into each other and side step the issue?
