Top Device usage % in Summary Report
MNF123
I have a device model MS250-48LP which has a usage (%) exceeding 50%, should I be worried about this information? If yes, is there a solution?
DarrenOC
Is that by any chance your core switch or has the uplinks into your MX?  I don’t believe this is anything to worry about.
DarrenOC
MNF123
Dear DarrenOC, thank you for the reply.
as for your answer:
  1. Is that by any chance your core switch or has the uplinks into your MX?
    MS functions as an access switch, which has an uplink connection to the MX.
  2. I don’t believe this is anything to worry about
    Do you have a link or document that states this information?
Regards,
MNF123.
KarstenI
With "access-switch," do you mean that there are *no* VLAN interfaces configured on the switch? If you have, the report will count all of the connected clients as coming from this switch.
