Meraki Ap Clients Vlan Tagging
Alper_YILDIZ
Just browsing
I'm new users for meraki AP .
cisco backbone and MERAKI acces point.
vlan 53 to get acces point ip and vlans 15 ,53,62,167,200 that acces point will broadcast.
When the device is connected to the access point, although there is no vlan 53 tagging in the interface, it gets an ip from x.x.53.x via the dhcp server.
I couldn't find the solution. maybe i posted in the wrong place i don't know but
Ryan_Miles
Meraki Employee All-Star
Yes, change it to just have VLAN 200 in the default line. No need for that "demo" line.
7 Replies 7
I assume the DHCP mode on the SSID is set to bridge.
In that case, you have to configure the VLAN Tag in the SSID for the VLAN you want.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
Alper_YILDIZ
Just browsing
yes, I looked at them and tried, but there is a situation like this.
Users connecting to the access point receive ip from the block they should not receive.
because the access point mngmt blocks 51 , 52 , 53.
Other ip fields are ap s on sws they are correct.
Is it my mistake here? I say add vlan and add the vlan I want to migrate. Do I just say default vlan and enter vlan number?
Ryan_Miles
Do your APs also have that tag "demo"?
Alper_YILDIZ
Just browsing
No instead of connecting to the system I asked if there was a mistake we made on my own demo.
Ryan_Miles
Alper_YILDIZ
Just browsing
thank you for everything
