MX85 to other brand firewall - VPN does not sustain with failover to backup Verizon 5G backup ISP
MarcW
I tried to make the subject all the key details.  I have a successful MX85 to TZ VPN connection on my primary ISP.  The HA failover VPN works because I set up a VIP for the redundant MX85's.
However, when I fail test the ISP, the internet is accessible, but the tunnels never re-establish over the VPN.  I have the 2nd IPSEC on the other end set to what becomes the new Public IP on the MX85 backup.  I waited a good 10-15 minutes to see if the tunnel would ever re-connect.  No joy.
I am sure there is some fundamental step I am missing, but it eludes me.  Reading is fundamental, but apparently firewalls are not.
Did you do a packet capture to see if you are actually trying to establish the tunnel with the VIP's IP?
I've seen cases where MX tried to use the interface IP instead of the VIP.
Is 5g a seperate router connected to  mx wan2 or is it integrated  into one combined isp router?
Is there any nat/cgnat on the 5g router?
I'm guessing the remote party has a static IP address configured as their peer address for you.
I'm guessing your 5G connection has a dynamic IP address?
If the above is right - can you see why this will never work?
