iPads in Kiosk Mode losing WiFi and won't reconnect
Kaitlin
Just browsing
I have 6 iPads (9th Gen) that are in single app Kiosk mode using the PropioOne app (a language translation service app) that are losing WiFi connection.  These devices are not used regularly. The devices get an error on the screen saying "Guided access app not available, contact your system administrator" and the devices are essentially bricked.  The screen will not let me enter the passcode, the touch is unresponsive, even after multiple reboots it will not connect to network or respond to touch.  The only way I can get the devices to work is to restore and start over.
I have manually put each device into single app mode for PropioOne.
Here is the profile settings:
The only work around I have found is to have the device displays never turn off.  Does anyone have any ideas on why this is happening?  I have other devices in single app kiosk mode with no issues but they are used all the time.
Thanks!
5 Replies 5
BlakeRichardson
If you have a Apple USB ethernet adaptor plus a Apple lightning to camera adaptor you can make a makeshift ethernet adaptor
Kaitlin
Just browsing
I don't have that equipment but this is more for after the device drops off the network.  I am trying to find out why they are dropping off the network in the first place and preventing it from happening at all.
BlakeRichardson
What is your wifi coverage like and what method of authentication are they using?
Kaitlin
Just browsing
We have decent wifi coverage over the entire facility with access points distributed all over the facility.  They are planning on doing an overhaul in 2025. Our authentication method is WPA2-Personal with PSK (Preshared Key).
I am wondering if the guided access setting in accessibility is another factor in it not responding because none of the accessibility settings are setup by default on the devices.
GreenMan
Have you tried deploying a second WiFi profile, for an SSID that is normally not advertised, that you can enable if you ever lose touch via the primary profile?
