You can try a few things, such as verifying the ADE token in ABM and Meraki, creating a new ADE profile with authentication disabled, restoring the iPad to factory settings and retrying setup, and avoiding URL enrollment unless you're using manual post-setup enrollment.
If the issue persists, I suggest you open a Meraki support case.
