iOS Web Clips not appearing
BM
I'm trying to setup some web clips to show on Supervised (DEP) iPads.
The clips don't show up on the device anywhere for a user to use. I've then tried to add a home screen layout, as these devices will have a few hand picked apps on them only (Kiosk like devices). Here are some screenshots showing my config. Interestingly, Settings -> General -> Device Management -> Meraki -> More Details shows the clips, so I'm not sure why I can't then use them.
Can anyone point me in the right direction to get this sorted?
I do have this setting set, but I'm pretty sure this shouldn't affect it?
Thanks in advance!
Inderdeep
Inderdeep
BM
Thanks @Inderdeep
I can now see my clips, unfortunately though, I can see them all 7 times! Any ideas on this one?
Additionally, spaces don't seem to be coming through, so "Example Clip" is showing as "ExampleClip"...?
Inderdeep
@BM : Can you try to delete and re-add them ?
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
