add a device
Normancssmi
Just browsing
add a device
When I ask to add a divide, I get a message that tells me to enter my email address and password, but I never configure that. How do I add a currency?
5 Replies 5
Inderdeep
If you are asking on how to add a device on Meraki Portal, Here is the doc
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Adding_and_Removing_De...
www.thenetworkdna.com
Normancssmi
Just browsing
I'll try that.
Inderdeep
Yeah let us know if you face any issue
Normancssmi
Just browsing
the procedure didn't work because I only work in EMM. only for cell phone and laptop
Meraki_Gwen
Hi @Normancssmi
My name is Gwen, and I would be happy to assist. What you are most likely running into with adding devices to Systems Manager is Enrollment authentication this setting can be found under Systems Manager > General page. For your protection, this is automatically enabled on all new Networks, and the enrollment authentication method defaults to "Managed: Use Meraki hosted accounts." These accounts are created under your Systems Manager Owners page.
https://documentation.meraki.com/SM/Device_Enrollment/SM_Enrollment_Authentication
https://documentation.meraki.com/SM/Other_Topics/Owners
Meraki Support's recommendation is to have enrollment authentication setting enabled in all dashboard networks, as this protects your network from having just anyone from enrolling devices. However, if you would like while you are actively enrolling devices the Enrollment authentication setting can be disabled and re-enabled when you are done.
Please let me know if you have any further questions or if there is anything that I can clarify.
