Where is the setting to allow devices to only connect to a certain SSID?
MidsterKI
Where is this setting?
forceWiFiToAllowedNetworksOnly
That showed up in something in the case we opened but cannot find where to set that in Meraki after searching for 45 mins.
Thanks,
Amit
It's under Network-Wide > Configure > Users:
It will work just for SSIDs that use Meraki cloud authentication.
PaulF
Android: Android device Owner > Disable Configuring WiFi
iOS: Restrictions > Force wifi to allowed networks only
Hope that helps
Paul
