- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Web Clip URL
I have a URL that I need to change. They current URL is no longer valid. The new URL is longer that 255 characters.
When I try to add the new URL I get the below error message
"There were errors in saving this configuration:
- One or more errors occurred. No changes have been saved.
- Test - ^Web Clip URL cannot be longer than 255 characters."
I have a test profile that I use as well. I have created a whole new web clip and get the same error message each time.
The URL is super long and it is used by thousands of other companies so getting is change is not an option. I am new the the Meraki MDM, but have used other MDM's in the past. Am I just missing something when adding the new URL?
Thanks for the help in advance
Mark
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you use a URL shortner? The error is saying 255 charactors is the maximum, theres no way around this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Blake, Thank you. Unfortunately there is no way to shorten the URL, The URL is from the company for the web link, and thousands of other depts around the country use it as well. Thank you for the info, I will have to look into a work around for them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That seems like an excessivly long URL for something thats so important, surely the company could setup a http redirect from a custom short URL.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You would think they would. I counted it up yesterday and it is over 300 characters long. I have work around for now which they are happy with still a pain though. Thank you again for your help.
