Thanks Paul,
I did some testing and created a new SCEP certificate specifying the username as the CN:
and then I specify this new SCEP into the Wifi Configuration:
When I enroll the device now I have one certificate installed with the CN field populated with the username specified on the Owners list, however on the Wifi profile installed on the device there is no user certificate configured on the profile.
If I select the default SCEP under Wifi settings and select "Use username as certificate CN" :
I do get a user certificate on the Wifi Profile on the mobile device however this user certificate does not include the username in the CN field, it contains a random number instead.
Is there a document that explains how SCEP policies are applied to Wifi settings and how to specify that the CN field contains the username for the default SCEP?
Any comments are really appreciated.
