@Seshu
Support has given me an answer so far of that variables are supported in this method for setting up Proxy Pac files, which doesn't quite seem right as variables "should" be able to return data whenever they are called.
I have also opened a case with Apple Enterprise support to see what they have to say on the matter.
I would think if other MDMs can do this functionality then Meraki should be able to as well.
