Urgent need : Zebra CC6000 on Android - Lock to display single webpage in fullscreen
JoLec
I've been looking for a solution for this for a few days and going through the help guides and community posts and didn't find any viable solution so i'm submitting it here to see if someone can propose something I havent found / tried yet!
Our need: we have a new Zebra CC6000 android device that will be setup as price checker/validator in our stores and all I need is to set them on a specific webpage (using chrome or whatever else works) so that it is displayed in fullscreen (no address/tabs/nav bar etc ) and to disable the touchscreen of the device.
I've been able so fak to setup the device with Chrome as a single app in kiosk mode and push the homepage setup to what I want... but can't figure a way to set it in fullscreen (from what I've found, might not be possible with chrome?), can'T disable the touchscreen and also have to start chrome from the kiosk panel, it doesn't auto start (like the "single app kiosk" available for iOS).
Anybody got ideas? free (or paid) apps that could be useed instead of chrome? it's a simple webportal with a link to an SAP webpage inside our network.
Any kind of ideas or help will be greatly appreciated!
If I find something  eventually, I'll let you guys know here in case it might help other people in a similar situation.
I don't know the answer.  This solution talks about using an app called "Fully Kiosk Browser".
https://community.spiceworks.com/topic/2243794-what-s-the-best-way-to-use-an-android-tablet-in-a-ful...
JoLec
A bit sade that I couldn't completely "SM Meraki this solution out" but this will do the trick with some extra cash to buy this app! Thanks for the tip!
Gracie-Mae
You’ve set it up pretty well so far. For fullscreen and disabling touch, a kiosk browser app might work better than Chrome since those usually have more lock-down options.
PaulF
So, two things:
Managed app config on Chrome on Android is excellent. There's almost nothing you can't do. There's 170 settings that can be tweaked to get the experience you want:
 More here: https://chromeenterprise.google/intl/en_uk/policies/
Secondly, have you considered using a Web Clip instead of a web browser?
1. Go to Systems Manager > Apps
2. Click Add App then Android, ensure that Play Store App is selected and then click Next
3. You should see a bunch of apps:
4. Click the little Globe icon, underneath the Blue Triangle
5. These are where you can create your web apps
 6. Click the + in the bottom right
7. Give it a title, a URL and decide how you want the app to work: full screen would appear to be what you need to select
8. select an icon, as necessary
9. Click Create
10. Once created, click select app
11. deploy as necessary
12 . It appears as a regular app now, which means...
13 You can now select it as a kiosk app:
No need for third party kiosk web browsers.
