We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi folks,
is there any training for the MDM out there?Only found this on YouTube: https://youtube.com/playlist?list=PLTVCI_tE32rQ_Om6tPbZHP2G1x10gUMOV
Regards
Solved! Go to solution.
Oh my God, it was so obvious.
case solved
https://documentation.meraki.com/SM
Here you can find all available courses.
https://community.meraki.com/t5/Learning-Hub/ct-p/hub
If it's not available here the answer is not.
very funny 🤣
What is so funny?
Sorry, I was a little frustrated, as it probably ends up being more of a learning by doing thing.
The learning hub is the first place for all community members....I hope
You could also see if your login gives you access to:
https://learning.meraki.net/
As well as the above, I maintain a Youtube Channel called Merakiminute that has short videos across all of the capabilities at Meraki. Especially Systems Manager: https://www.youtube.com/playlist?list=PLFwlU-gQMpUgRhoidGgUWwCfE2QTpqyoF
If there's anything that you wish we had a video for, just let me know and I'll research and create one
PaulF sounds great. I'am a fan of these series of videos. 🤠
I'll take a look and come back to you it's okay?At the moment I'am testing out the different features of SM, by checking out the documentation and several YouTube-videos.
Este conjunto de videos está muy bien. Os recomiendo también este curso de Linkedin Learning:
https://www.linkedin.com/learning/certificates/d0dd6e5f803dc443c455592db12faf616a278c120554627c8089c...
Gracias.
