Systems manager meraki scheduling doesnt work with an employee tag.
arushdesp
Just browsing
I have an employee tag with some devices. Then I created a scheduling tag lets call it "scripting afternoon tag" that whenever I associate both the employee tag and the scheduling tag in the app i have created the device target list becomes empty.
The scheduling tag seems that isnt functioning as expected. I always add "Any of the following tags".  Status of the scheduling task is always out of schedule. Additionally I havent touched the do not distrub section of the configuration settings.
ConnorL
If you believe you're hitting a bug or unexpected behaviour, please open a Support case.
arushdesp
Just browsing
I would consider it a bug as the script is working but the target list show no devices. Is there a different section for the bugs?
ConnorL
Nope just open a regular Support case. That way they can troubleshoot with you, validate and forward the bug to our Engineering teams.
