- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Cannot add Android apps to Meraki
I have Android Enterprise setup to add apps through Meraki to Android devices. I am unable to search for any Android app (either by name or identifier), however I can add it through the Play store for Work account. If I add it in that way, there is no option to sync Android Enterprise account under the Sync button in apps and it was definitely there previously.
I have not changed any settings so am at a bit of a loss on this. I have contacted Meraki support and they unfortunately haven't been helpful.
Any help on this would be greatly appreciated.
- Labels:
Android
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm also having this problem. Anyone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is the normal way for adding apps for android:
If this is NOT your normal workflow for adding apps, can you list the exact steps you take to add an app
