Server 2012 R2, 2016, and 2019 no longer supported in SME 4.0+
BHC_RESORTS
According to support, only Windows Server 2022 is supported going forward in systems manager version 4.0 and higher.
Can someone from Meraki comment on this decision? Server 2016 and 2019 are still fully supported operating systems by Microsoft. Even 2012 R2 is in extended life.
Not being able to manage 75% of our server environment is not going to make it worthwhile for us to use SME.
BHC Resorts IT Department
BlakeRichardson
@BHC_RESORTS where did you read that. I can only see the below.
Version 4.0
  • [Update] Name of agent is now Cisco Meraki Endpoint Agent.
  • [Update] Dropped support for operating systems: Win10 21H1 (and prior) and macOS Mojave 10.14 (and prior).
  • [Update] OpenSSL Support 3.1.1.
  • [Security] Various bug fixes and security enhancements.
Windows
  • [Update] Bulk enrollment support added.
Source https://documentation.meraki.com/SM/Device_Enrollment/Systems_Manager_Agent_Release_Notes
BHC_RESORTS
Directly quoted from our ticket:
"Unfortunately, versions 4.0+ of the Systems Manager agent require Windows 10 22H2 (OS build 19045) and above or Windows Server 2022 and it's not supported in older versions. We are working with our internal team to update this in our documentation."
BlakeRichardson
Seems odd that MS supported versions of Windows server aren't supported then again I don't really know of any people that manage servers via an MDM as most don't support Windows Server.
