Hiow do I send out a push message to all enrolled devices from Systems Manager? These devices are all ADE enrolled iPads as well with no SMS or calling enabled.
If you have the settings @ekramer configured then you should be able to do it from the device list. If you click the checkbox for the devices you want, there's a drop-down list called "Command" and you can choose "Send notification" from there.
To send a push notification message to the iPad devices, you need to (A) have the Meraki MDM app installed and (B) the user must allow it to present notifications.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_85802cf67ced0e","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_85802cf67ced0e_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_85802cf67ced0e_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_85802cf67ced0e_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_85802cebf54afa","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
