- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Sending enrolled devices a message
Hiow do I send out a push message to all enrolled devices from Systems Manager? These devices are all ADE enrolled iPads as well with no SMS or calling enabled.
Solved! Go to solution.
- Labels:
ADE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you have the settings @ekramer configured then you should be able to do it from the device list. If you click the checkbox for the devices you want, there's a drop-down list called "Command" and you can choose "Send notification" from there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To send a push notification message to the iPad devices, you need to (A) have the Meraki MDM app installed and (B) the user must allow it to present notifications.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
