Sending a Wi-fi connection via MDM
rraglin
Just browsing
Is it possible to send a Wi-Fi profile to MDM phones and ipads?
EClap5
@rraglin- Yes you can create/push all kinds of profiles with the Meraki MDM.  Here is some great info on creating profiles - https://documentation.meraki.com/SM/Profiles_and_Settings/Configuration_Profiles.
For non-cellular devices, you'll just need to make sure they have some sort of connection with the MDM if you want to push the profiles remotely via Dashboard.
Yes, and if you have Meraki WiFi kit it is even easier - you just select the existing WiFi network you want to push to the devices.
scheived
What is this WiFi kit?
I have meraki AP but can't get MDM to create a wifi profile on android phones
PaulF
