See unmanaged apps and which devices have them
Antonio1
Just browsing
In the dashboard you can see a summary of the unmanaged applications in your organization, but I don't know how I can see all those applications and what devices have them. I can only see them if I go device by device.
Is there an option to see everything in one document?
Thank you so much.
PaulF
Systems Manager > Software:
This will give you EVERY piece of software installed
Clicking on an app will give you:
This information should also be available through the Meraki Dashboard API if you want to pull it into your own spreadsheets, etc.
https://developer.cisco.com/meraki/api/get-network-sm-device-softwares/
BlakeRichardson
@PaulF being able to see if software is managed or not through the list view would be useful.
PaulF
Agreed! I'll feed this back
