So the goal was to put the device back to the state it was in before we added the work profile.  I had to do some digging and research to eventually find the solution that worked.  Below is what we did:
Remove google account in settings
Unenroll device from the network
Uninstall SM from the device
Remove device from network
Remove work profile from phone
Reboot
After doing the above, her phone was back to normal.  If someone knows an easier method, please do post.
