SM Android app permissions get reset after reboot
dbl4500
After we enable the permissions for the Meraki SM app shown in the app's "Alerts" section (see photo), the permissions get reset after a device reboot.
Device Model: SM-T638U
OS Version: Android 14
Have you tried reinstalling the SM agent?
Also take a look at this.
https://documentation.meraki.com/SM/Monitoring_and_Reporting/Troubleshooting_SM_Clients_that_Fail_to...
Allanscott
Here are some potential solutions to resolve this issue:
  1. Check Device Policy: Since the device is in device owner mode, ensure that the device policy settings allow for the required permissions to persist after a reboot.
  2. Auto-grant Permissions: Some enterprise mobility management (EMM) solutions, like Meraki, have options to automatically grant permissions to certain apps. Make sure these settings are correctly configured.
  3. OEM Settings: Some OEMs might have additional settings or restrictions regarding permission management. Check if there are any Samsung-specific settings that might be causing this.
  4. Update Meraki SM App: Ensure you are using the latest version of the Meraki SM app. Sometimes, app updates include bug fixes for issues like this.
  5. Android 14 Compatibility: Since you are using Android 14, there might be compatibility issues with the Meraki SM app. Check for any known issues or updates from Meraki regarding Android 14 compatibility.
  6. Re-provision Device: As a last resort, re-provisioning the device might help in resetting any configurations that might be causing the issue.
To provide more specific guidance, I would need additional details, such as:
  • Whether this issue is occurring on multiple devices or just a single device.
  • If there are any custom configurations or policies applied to the device that might affect permissions.
dbl4500
The solution was that the device has to be rebooted via holding the power button instead of just unplugging the power cable (device has no battery inserted).
