Possible to disable/block the SM Agent across organization?
somefox
Is it possible to NOT install Meraki Systems Manager Agent (macOS) across my entire organization? Can I disable or remove it? I see I can push the agent with the profile installed but my security team does not want this to be possible. I get all the features that I want from the profiles without the privacy concerning functions like remote screen share and remote terminal.
2 Replies 2
Why not leave that feature (or other features you are concerned about) disabled?
https://documentation.meraki.com/SM/Other_Topics/Systems_Manager_Remote_Desktop#Using_Remote_Desktop
BlakeRichardson
@somefox Yes just simply don't install it, if you have already installed it then you will need to uninstall it.
It uses port 993 which is shared with IMAP so you simply can't block this port.
