I'm trying to restrict the ability of users to change the Passcode, and I'm not having any luck.
Here's what I have setup as a test.
I have one Profile with Restrictions Enabled, with a lot of Restrictions, but I have the following setting OFF:
[ ] Allow modification of passcode settings
Scope is 'with ANY of the following tags';
Device tag 'TEST'
I made a security policy under Policies named 'PWD'. The only thing enabled is "Passcode lock"
I created a second Profile.
No additional Restriction settings.
Wallpaper settings enabled. Lock and Homescreen. (Created this as visual test that Profile is pushed.)
Device tag 'TEST'
Policy tag 'PWD - violating devices'
Yet, I'm still able to change the Passcode. I first tried putting the PWD Policy on the TEST Profile, but for some reason, enabling a Policy Tag on this Profile, pushes the Profile off the device. That's when I read that you should create a second Profile for a Policy. After doing this, the TEST Profile is not pushed off the device, the PWD Profile is on the device, but I can still change the Passcode and the Wallpaper is not changed.
Additional Notes: This device is NOT DEP enrolled. This device is manually enrolled.
Is there something that I'm missing?
Thank you
