Meraki license for my iPhone 15 pro max
Juukdit2020
My organization have a meraki Enterprise Systems Manager license and i need to add or purchase one Meraki license for my iPhone 15 pro max, what type of Meraki license I should buy?
so I can search it on CCW
KarstenI
The Systems Manager licenses don't differentiate between different devices. Just get the needed amount for the same license that you have.
Juukdit2020
Yes, I thought about it before it make since
I believe your answer will be correct
BlakeRichardson
With systems manager the only options for licensing is the license length i.e. 1,3 or 5 years.
PaulF
Meraki Employee All-Star
search for LIC-SME-1YR and you'll find it. replace the 1 with 3 or 5, as appropriate
