Hi there,
We seem to be having an issue on multiple devices. That when an app is uninstalled it still shows as installed on the device. Even though we are manually triggering the refresh apps list task.
These devices are enrolled through DEP and have the System Agent installed with permissions granted
Solved! Go to solution.
For a general rule to help with troubleshooting, Meraki Systems Manager runs the following command to collect the apps installed on macOS:
system_profiler -xml SPApplicationsDataType
Feel free to check the local output of this^ command to make sure the apps were cleared from system_profiler on the macOS device. If they are removed locally with the system_profiler output but never removed from Dashboard, please open a Meraki support case for this with the reproduction steps outlined and we should be able to get this over to the development team for further review.
@_aDiedericks If you select "refresh device details" from the command menu and wait a few minutes does that help?
I have tried this multiple times already. The refresh process is successful every time but the applications remain there.
I can only confirm that app properly uninstalled from the device. Any of the apps mentioned that are marked as installed on Meraki are in fact gone from the device.
That was quite helpful thanks. I can confirm it's showing the apps still installed. After restaging the MacBook and enrolling it, seems install and removing updates correctly.
With the latest improvements to the agent I think it may become more reliable
