Meraki Endpoint Management
OrlUV
Can you deploy Meraki Endpoint Management to your existing network which does not include any Meraki device? Kindly advise !!!
DarrenOC
Hi @OrlUV , are you asking if you need to have a Meraki deployment of switches, APs etc to allow you to deploy MDM - systems manager?
If so, the answer is no.  You can just deploy Systems Manager on its own for device management of your endpoints.
2 REPLIES 2
DarrenOC
@DarrenOC , Thanks alot.
