- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Meraki Agent Issue - Devices Not Showing Up
Hi All,
I am having a weird issue whereby new machines are not showing up in the client/device list after the Meraki Systems Manager Agent is installed. Same behaviour on re-imaged and brand new devices out of the box. This was working until very recently and seems to have "broken" all of a sudden. Mostly W10 and W11 devices we use, both of which seem to be impacted. I downloaded the latest installer available (3.0.2) to us under Manage -> Add Devices -> Download, but unfortunately outcome is the same. We have tried with an old installer from way back and also seems to be the same.
Troubleshooting steps so for:
- Uninstall, reboot, reinstall, reboot
- Repairing the install.
- Installed latest version available and older version, no joy.
- Disabled Local Windows Firewall, no joy.
- Installed via command line referencing the enrollment code, no joy.
The install shows this message, but I think this always happened but not 100% sure.
Typically when an agent is installed, you can see the device go to "unknown" as it runs inventory/sync and then shows the host name etc after some time, but this doesn't seem to be happening anymore.
Given different installer versions are all giving the same result, that suggests to me it is possibly something in the environment that has changed, or has stopped working correctly but am not sure.
Anybody seen this before, or have any tips on where to troubleshoot next?
Thanks all.
- Labels:
Enrollment
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you opened a support case?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you looked at the log files to see whats going on?
Agent logs on Windows vary by agent version. These logs can be found at the following locations:
Agents ≤ 3.6.0:
C:\Windows\temp\m_agent_service.log
Agents ≥ 3.7.0:
C:\ProgramData\Meraki\Systems Manager Agent\Logs\m_agent_service.log
System logs are found in the Event Viewer:
Windows Logs/Application and Services/Microsoft/Windows/DeviceManagement-Enterprise-Diagnostics-Provider/Admin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi BlakeRichardson,
Thanks a mil for your help and suggestions. I was able to find some info in the m_agent_service logs:
Also saw some errors like this as well:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Then event viewer showing these errors:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This might also be helpful.
https://documentation.meraki.com/SM/Other_Topics/Systems_Manager_Logging_and_Troubleshooting
