Meraki APP
MSH
Meraki APP
I installed the Meraki App on my Android; actually I can only see the sensor, not even the camera and not the other devices?!
According to the description in GooglePlay everything should be visible?
Kind regards, Volker Boeckl
11 Replies 11
You should see them all.
Did you select the correct organization > network
On the left side of the app
MSH
SHOULD...?!
What SHOULD be displayed is clear...
BUT actually I can only see the sensor, not even the camera and not the other devices?
KarstenI
Please also read lines two and three in the response.
In addition to that: Do you see it in the dashboard with the same credentials?
MSH
no, I always only read the first line 🙄
If this answer didn't help you can simply open a support case. 😉
MSH
Thank you very much for this helpful answer, I would never have thought of that...
I don't understand why you are being so sarcastic towards community members.
@ww  just asked some questions to better understand your case.
You just arrived in the community, so I believe you could be a little more humble. We all here just want to try to help in any way we can.
MSH
But these answers are not helpful; if there is nothing better related to my question, then it would be better not to answer...
And it has absolutely nothing to do with how long I have been in this group... 1 hour or 1 year...
In my opinion the answers are completely useless compared to my question.
KarstenI
No one here knows about your background regarding Meraki. And you also don’t say what you already have tested. With that, these questions are more than valid.
Make sure you have selected the correct organization and network in the application. You can also try to reinstall the app. Otherwise, it is recommended that you open a ticket with Maraki, as this is supposed to work and may contain a BUG.
Have a great day.
KarstenI
Don‘t be huffish … We all want to help; but your problem description is so vague that more information is needed.
